GHQ Site Admin
Posted: Fri Jul 31, 2009 3:45 pm Post subject: ZM-10 SP Caboose #1 |
Making Narrow Gauge Passenger Cars in N-Scale
Southern Pacific Combine / Caboose #1 in Nn3
This car started life as South Pacific Coast Railway #47, built by Carter Bros. in 1880. It came to the desert line in 1906 and became caboose #1. It lasted in service into the 1940s until retired.
I built this model in the 1980s from what was then available to kitbash, the Bachmann old-time passenger cars (the combine is Bachmann’s #75551). They remain one of the best resources for narrow gauge cars, along with the MDC/Athearn Overton and Overland cars. (The Rio Grande set is Athearn #11023) These cars frequently turn up on E-bay and at swap meets.
I have done a number of Nn3 narrow gauge passenger cars over the years. I will share them with you in future articles.
SP #1 is quite a straight forward conversion. A very fine plan of it was published in Mal Ferrell’s Southern Pacific Narrow Gauge (PFM, 1982).
The first thing that I did was carefully razor saw the roof off, the fascia board is too tall anyway. I sawed it off right under the roof edge and used the lip of the roof as a guide for the saw and started lightly and slowly. Next I razor sawed down the middle of the roof. The car is 8 feet wide so the edge of roof should overlap that slightly. I filled the cut roof edges, narrowing the clerestory until the two roof halves were slightly over 8 scale feet.
Then I glued these halves together. Next I scraped all of the rivet and seam detail off the roof. After it was completely dry, I razor sawed out a section to make the roof the right length.
The sides were quite easy. I razor sawed the sides off, cutting into the ends of the car, using the sides to guide the razor saw. The corners stay attached to the ends of the side to keep the lantern bracket detail on the corners.
I used a new chisel blade to carefully cut off all the beading around the windows. Next, I shortened the car by taking out, and shifting, segments to create the correct sides, leaving extra width on the baggage door on each side. I widened the door slightly and left enough material to glue the doors on the inside, giving them the proper depth. The sides were reduced in height a bit and a new fascia board made, and notched, for the door. Window mullions were cut and replaced to have four windows per door.
New ends were created using Evergreen siding which matches the car siding quite well. The end doors were cut out of the Bachmann car ends, reconfigured slightly and used on the ends again.
The Bachmann car bottom was shortened and used. Queen posts made from brass wire were drilled into the bottom. I used nylon thread for the truss rods. Today I would use .010” brass wire and solder them onto the queen posts with low temperature solder (very quickly so as to not melt the plastic bottom!)
The rest was all quite unchallenging: bending wire handrails, ladders, trucks and couplers.
The car was painted what the Espee called “Sunburn Red” and then weathered heavily for the desert.
This kitbash makes a very nice representation of caboose #1.
As always, thanks for looking. Please share your feedback with us. Did you like this article? Why? Why not? Was there enough detail? Did this inspire you to actually do this project? Did it inspire you to do a different project? We are trying to stress that model railroading is actually a modeling hobby, and that literally anything is possible in N-Scale. Model railroading is also a social hobby. We are sharing some of our projects with you here. Do you have any that you can share? Anyone who is registered for our forum can post, and that includes posting picutres of their own projects. If you aren't registered, then register**. Please share your pictures of your work, ask questions, answer questions...get involved.
Thank you for your support,
GHQ
** To avoid being bombarded with SPAM, all accounts are screened with human eyes. Please be sure to include something about model railraoding, military models, military history, etc. in the "interests" section of your profile when you register. Because of this there will be a lag time between when you register, and when you can initially post- the lag will be longer on weekends. Once your account has been activated, you can post immediately, whenever you like. |
