Each pack contains the following:
• 14+ men with Panzer Fausts (some kneeling & firing, some advancing)
• 8+ two-man teams with the 8.8cm Raketenpanzerbusche 54 (Panzer Schreck). Each team has
one man aiming the weapon, and the other kneeling with a reload rocket.
• 8+ bases for the ground mounted weapons. Each has has one crewman mounted on it.
Ground mounted weapons:
• +2 SchwerePanzer Busche '41 (a 25mm taper-bore gun), each with a seperate kneeling gunner
• 4+ 8.8cm Raketenwerfer 43, commonly known as the Puppchen, each with a seperate seated gunner
- Equipment Type:Anti-tank weapons: man packed
- Equipment Type:Heavy weapons
- Era:WWII
- Country/Region:Germany
- Scale:1:285/6mm Scale
