1/4 inch Hexes - River, Shore, Open Water
SKU: TM2
1:1200 Scale 1:160/10mm/N-Scale 1:2400 Scale 1:285/6mm Scale Other Hexes
Terrain Maker® is a geomorphic wargaming terrain system based on double-density Styrofoam hexes measuring four inches from side to side (Terrain Maker hexes are 4" from the middle of one side, through the center of the hex, to the middle of the opposite side.) The thickness of the hex determines the type of terrain it models.
Per pack: TM2 contains 48 hexes (each 1/4-inch thick), plus enough tree materials to make 16 trees, and instructions.
This is the standard river/stream or minus one level Terrain Maker hex.
Use them to model beaches, lake shore and open water features.
(The photos above show stream beds made with TM2 hexes within flat lands made from TM1 hexes. TM1 and vehicles sold separately.)
**Please note - Due to the high costs of shipping Terrain Maker outside of the contiguous USA, the standard 20% of the merchandise total that we charge for international shipping is not sufficient. If you live outside of the contiguous USA and are interested in purchasing Terrain Maker, please contact GHQ at customerservice@ghqmodels.com and tell us where you live and how much Terrain Maker you are interested in purchasing. Thank you!
  • Scale:1:1200 Scale
  • Scale:Other
  • Terrain Maker:Hexes
